If you exit all unnecessary applications and processes the installer will usually run ok. But otherwise Mach3 reports the DLL as corrupt because it can't find the KMotionDLLs required for it to load. These are located into the install directory as <Install dir>\KMotion\Release. The installer adds an APP Paths entry in the registry for Mach3 so it can find them. You can add this manually.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Mach3.exe
create a string entry called path that is set to:
C:\KMotion431s\KMotion\Release
(or whatever your installed directory is)
Another option
is to change the Windows PATH environmental variable
Message: 9240 |
Date: 2/20/2014 |
| Subject: Re: kmotion wont install on win7 64 bit |
Tom, Wow what a fast and correct response! I added the lines to the registry" modified to match my directory" then rebooted for good measures and all is good! Thanks, Phil
